Caravan
Oct 27, 2024Aspirant
RBR850 slow
Hello,
I have a 1 Gig internet connection. The connected devices have shown 200 to 300 Mbps for the past few days, and the internet has become very slow. I tried connecting the router with a LAN cable to a MAC, but it had the same slowness.
Spectrum tech said the Modem is giving the Router about 950 Mbps.
My Orbi app shows full speed, but all the devices connected to the Wi-Fi are 50-60% slower; I have checked using Ookla.
The modem-to-router connection seems to pass at full speed, but the router is not passing at full speed . I tried connecting from the router to MAC with ethernet, and it was still more than 50% slower.
Firmware is up to date and rebooted multiple times.
|| || |Hardware Version|RBR850| || |Firmware Version|V7.2.6.31_5.0.24| || |GUI Language Version|V3.0.3.10_2.1.30.3| || |Operation Mode|Router|
Please help!
Is the first speed test with a wired PC connected directly to the ISP modem or ONT?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-messageTry disabling the following and see:
Armor, Smart Parental Controls or Circle, Traffic Meter.Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
