Mkstretch
Aug 02, 2025Aspirant
RBR850 Unable to join network
I have the rbr850 and 2 rbs850 satellites. I am running the latest firmware. This is a new setup. My devices every few days will disconnect from the Orbi router and when I try to reconnect it says “u...
Aug 03, 2025Guru - Experienced User
what modem/gateway is the router connected to?
Mkstretch
Aug 03, 2025Aspirant
My Orbi is plugged into an unmanaged switch coming from a moca adapter. My router is a fios gateway
- FURRYe38Aug 03, 2025Guru - Experienced User
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...- MkstretchAug 03, 2025Aspirant
I have my fios router WiFi turned off and my Orbi router is in AP mode
How is AP mode configured on the RBR? Dynamic or static?
Try Static configuration:Static IP Address Configuration for AP Mode | NETGEAR Communities
