hkoppp
May 10, 2021Star
RBR850 V3.2.18.1_1.4.14 latest firmware CONSTANT DISCONNECTIONS
Guys, ever since latest firmware update on my orbi router im having constantly daily disocnnections at least 5 times per day
never happened on an older firmware version
i cant use my internet like this
spent 2-3 hours of different level support netgear being passed around
just to create a ticket about the issue going no where
need help
i want to downgrade to a stable version but it keeps reverting back to latest version firmware
any idea guys?
been using my orbi router with 1 sat for 3 months no issues until this new update came out
random disconnections
Has a factory reset and setup from scratch been performed since last update?
- Does the actual internet connection disappear from the Orbi web interface?
- Does the Orbi WiFi signal drop?
- Does it appear that the DNS function stops working?
i.e. you can 'ping' an IP address, such as 1.1.1.1 but cannot ping by URL one.one.one.one? - Are all devices in the network affected the same way?
is Traffic Meter or Armor enabled on the RBR?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.Any Wifi Neighbors near by? If so, how many?
hkoppp wrote:Guys, ever since latest firmware update on my orbi router im having constantly daily disocnnections at least 5 times per day
need help
any idea guys?
Have exact same issue. This is unacceptable Netgear. Why doesn't Netgear have a solution? I had the same issue with a previous firmware. Support had me change some settings and it was fine for a while and then Netgear forced new firmware on me (V3.2.18.1_1.4.14). This is garbage. I can't revert to the old firmware either. This is infuriating. The issue affects both wired and wireless connections. Anyone have a solution? Yes...I've power cycled my router and satellite (RBR/RBS 850). The solutions offered so far have not been helpful.
