Jhong721
Jul 10, 2022Follower
RBR850
How do I private message ChristineT? Can’t figure it out. I can’t connect to my Orbi RBR850 even after several reboots. I tried sending a private message and the name doesn’t pop up.
Jhong721 wrote:
I can’t connect to my Orbi RBR850 even after several reboots. I tried sending a private message and the name doesn’t pop up.While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
How do I private message ChristineT?Try ChristineT
You'll also have better luck if you include all the details of your setup (modem/router), how you're attempting setup, and where its going wrong. The more details you include, the better.
If its a new device, you also can contact support for help with setup.
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.
