cast7776
Mar 15, 2025Follower
RBR850
How do you update on a computer
- PhyberApprentice
Log in to your admin page (192.168.1.1) and migrate to the Update section. Or, better yet, download the appropriate updaters (router and satellite), and install them, from the Admin page manually. First the satellite(s) and then the router.
Follow this PDF guide to update Orbi systems manually using a PC:
The obvious method is to follow the instructions on page 93 of the User Manual:
https://www.downloads.netgear.com/files/GDC/RBK852/RBK852_UM_EN.pdf
- KevinLiTNETGEAR Moderator
Hello cast7776 ,
Welcome to the NETGEAR Community!
I understand that you would like to manually update your RBR850 using a computer.
Please follow the instructions embedded in the link below for step-by-step instructions on how to update the firmware on your RBR850:
Best,
Kevin
Community Team
