rimasidd's avatar
Feb 05, 2022
RBR850/RBS850 WiFi slow on a 1GIG fiber (getting 90Mbs up/down)
I have att 1 gig fiber (  1 RBR router ) - (4 satellites)  6500 SQ ft house
satellites are 25-30 ft apart on second floor < Router ( which acts as bridge) also on second floor ( hard wired to ATT)
used to get 350mbs , then has issues with drops so i disconnected one of the satellites. Still gets drops, but not that often, challenge is  over the last month WiFi speed has dropped to less than 100mbps down and up causing issues on all connected devices
v. 4.6.3.16 on router and satellite
Any ides thoughts on how to fix would be appreciated
Rima
    • rimasidd's avatar
      rimasidd
      Tutor
      Thanks i did all that .
      hardwired into att arris - 750 download, 930 upload
      hardwired into RBR Router - 94 ( upload 'download)
      reconfigured everything so that att Arris is set up a a bridge , RBR set up as router with pass through. Issue is hardwired right out of RBR speed is extremely low
      • Mikey94025's avatar
        Mikey94025
        Hero
        Thanks, now we know to look at the RBR speed drop and can factor out wireless for now.  So you have bridged your modem and wired download speed is 94 Mbps vs. 750 Mbps when removing the RBR?  That is surprising.
        Do you recall what default settings you changed on your Orbi?  Make sure you have not enabled Armor, Circle, Speed Test, Access Controls and Traffic Meter.
        As a last resort, how do you feel about factory reseting the Orbi and then seeing if the speeds recover?
