GregS_from_MI
Sep 11, 2025Apprentice
RBR860 intermittent disconnects
I have had this Router plus 1 satellite since March 2023. It is connected to Hitron EN2251 modem from Spectrum. The router and modem are plugged directly into the wall plug. Both sit in the open and ...
Sep 11, 2025Guru - Experienced User
Does the RBR or RBS front LEDs turn ON PINK or blink white when this happens?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
I use channel 1 and 40 on my Orbi systems.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
Armor, Smart Parental Controls or Circle, IPv6, Traffic Meter.
- GregS_from_MISep 11, 2025Apprentice
Here are my answers in Bold.
Does the RBR or RBS front LEDs turn ON PINK or blink white when this happens? Always turns white and flashing. Not fast.
What Firmware version is currently loaded? Firmware Version V7.2.7.15_5.1.16 I have Auto Firmware Update On.
What is the size of your home? Sq Ft? It's a ranch at 1400 sq ft overall
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected. The satellite is in the garage and is 40+ feet away.Does this happen with the RBS turned OFF? No, I haven't done that. Really didn't expect that would be a problem since the satellite was located a distance from the router.
Does this happen with both wireless and wired devices? Yes happens to both. My office has the modem and router in the same room. My desktop is wired to the router. But I see the disconnect on both wired and wireless at the same time it occurs.I use channel 1 and 40 on my Orbi systems. I'm currently on 11 and 48. There are only 4 channels available on the 5G.
Any Wifi Neighbors near by? If so, how many? I live in a small rural neighborhood. One on either side, plus across the street. No one behind us. I know this is not very scientific, but I have a WiFi Analyzer, freebie of the internet, I did a Channel Graph screenshot of 2G and 5G bands. Again I'm on channel 11 and 48.
Has a factory reset and setup from scratch been performed since last FW update? I am running on factory default right now. The default SSID is ORBI18.
- FURRYe38Sep 12, 2025Guru - Experienced User
You should change the SSID name to something different.
Is IPv6 enabled on the RBR?
Also might disable all logging on the RBR and see if this changes anything.
Be sure to use a good quality LAN cable between the ISP Modem and RBR. CAT6A STP is recommended.
Something you can try, manually re-load FW on to the system, RBS first, then RBR lastly. Seen odd problems and users posting about there systems not working well after a auto update. Manually loading FW with a ethernet connected PC and web browser seems to have better results. Something I always do with my Orbi systems.
Procedure to Manually Firmware Update Orbi and Nighthawk Mesh systems. | NETGEAR Communities
Does the RBS have good connection while in the garage and system is working? If not, maybe move the RBS a bit closer to the RBR.
- GregS_from_MISep 12, 2025Apprentice
Thanks, I'll check it out.
