MikeCook66
May 25, 2026Aspirant
RBR860 /RBS860 - Speed
My setup is 900mbps Toob ONT connected to RBR860 and the RBS860 connected via ethernet
Macbook pro with Ax network adapter
Issue
When i speedtest , even though I am only about 10 feet away from the router I never get above 700mbps , i would expect to get 900 ?
Any advice ?
MikeCook66 wrote:
Any advice ?
What does the speedtest built into the router give you?
Do you have a way to measure speed between two local devices? For instance, using iperf3.
What model Mac Book is this?
What model AX adapter?
What connection rate are you seeing on the adapter when connected to the RBR?
Most I've ever seen out of my Mac Book Pro 2018 is around 700Mbps which is good for that older laptop using it's native adapter.
