MeshedUp's avatar
Oct 30, 2022
RBRE960 & RBSE960 firmware update issues
My RBRE960 and two RBSE960 satellites are running firmware version 6.0.3.85. Noting that new firmware -- 6.3.7.5 -- has been released for these units, I attempted to upgrade and ran into the following issues.
The Orbi Web console firmware update page displays only the router, and neither of the satellites. The satellites are, however, connected and working. Attempting an Online Update to the router shows the status "Please wait a moment" for so long that the connection times out on every attempt. Shifting to manual update mode, I have downloaded the Zip files for both the router and satellites; however, because the Orbi Web console page shows neither satellite it is impossible to update them (and the Orbi manual advises to update the satellites before the router).  So......
Challenge #1: The Orbi console online update mode never finds the RBRE960 update.
Challenge #2: The Orbi console firmware update page shows neither of the satellites, making it impossible to update them
Any suggestions from those 960 users who have attempted to or successfully applied the new firmware?
  • FURRYe38
    Thanks for the tip. It worked as you described. In order to complete all three updates, I used the Orbi app to find the satellites' IP numbers and logged into each individually. One satellite took the update software on the first pass; the other satellite had to be re-booted before it would accept the new firmware upload.  The RBRE960 manual update worked fine also.
  • FURRYe38's avatar
    Yes,
    Connect to the RBS web pages using there IP addresses in a web browser and log in and send the RBS FW file using the RBS web page. I did this yesterday. No issues.
    Once ALL RBS FW files are sent, send the RBRs FW file. Once the units are back ONLINE. Power OFF The RBS and RBR for 1 minute then back ON with the RBR first then the RBS.
    • MeshedUp's avatar
      MeshedUp
      Tutor
