Nobber1066
Oct 15, 2025Aspirant
RBRE960 cant connect locally
For some reason I cant connect locally or via orbilogin.net or orbilogin.login to my Router, I just get refused to connect I can get in via the app When I reboot the router i get access of f...
- Oct 15, 2025
Ok so it appears to be working again all ok, not totally convinced but this is what I did
- Blocked a specific IP that I could not recognise obvs NOT my PC
- After that the problem started, could not connect locally but could through the app
- connected via edge on my phone turned of Access control
- then was able to connect via my PC
- Turned access control back on then everything started working agin as it should
Thanks for all the replies
Nobber
Oct 15, 2025Guru - Experienced User
What modem do you have?
Have you checked in the app to see what IP address the orbi router is using? Try connecting with that
Nobber1066
Thanks for the reply, dont have a modem I'm using a BT Hub in bridge mode, internet is working fine
the Router is 192.168.1.1
