Nobber1066
Oct 15, 2025Aspirant
RBRE960 cant connect locally
For some reason I cant connect locally or via orbilogin.net or orbilogin.login to my Router, I just get refused to connect I can get in via the app When I reboot the router i get access of f...
- Oct 15, 2025
Ok so it appears to be working again all ok, not totally convinced but this is what I did
- Blocked a specific IP that I could not recognise obvs NOT my PC
- After that the problem started, could not connect locally but could through the app
- connected via edge on my phone turned of Access control
- then was able to connect via my PC
- Turned access control back on then everything started working agin as it should
Thanks for all the replies
Nobber
CrimpOn
Oct 15, 2025Guru - Experienced User
Tried both http and https for the web connection? (there is an optional setting on Orbi routers to allow only https connections)
