Ekkoh
Nov 20, 2025Tutor
RBRE960 DHCP issue?
I have an RBRE960 with three RBSE960 units. Two are wired, and one is connected wirelessly. I’m experiencing major issues with my devices losing connection to the network. My iPhone suddenly drops t...
Nov 20, 2025Guru - Experienced User
What model iPhone do you have and what iOS version is on the iPhone, ATV and Mac?
Only happening with Apple devices?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Is IPv6 enabled on the RBR?
Using detected ISP DNS or custom DNS like Cloudfare or Quad9?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
What channel configurations are currently set on the router?
Try 1 and 40 or 11 and 48.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
- EkkohNov 21, 2025Tutor
I have different models of iPhone, both 15 and 16. The same goes for Macs, several different MacBook Pros, both older and newer models. I also have the latest Apple TV. I only use Apple devices wirelessly, so those are the only ones I can verify the issue on. However, other wireless devices like cameras also frequently lose their signal, so it’s likely happening to all wireless devices on the network.
I have fiber, and the converter in the house is a Genexis XG6846. I use CAT6A cable from the converter to the RBRE960.
IPv6 is enabled. ISP DNS is detected.My house is roughly 3,900 square feet. The building is very thick concrete and brick. The distance between the RBRE and RBSE units varies between 30–40 feet. I’m currently using Auto channel and 40, but I can try 11 and 48.
- FURRYe38Nov 21, 2025Guru - Experienced User
What iOS versions are on the phones and Macs and laptops?
Please disable IPv6 on the RBR. Been some known issues with Apple devices and IPv6.
I have IPv6 disabled on my 960 series currently online and not seeing any issues with my Apple devices.
Be sure to disable any MAC Address randomizers on phones and pads while at home.
Has this been happening all along or or just started happening?
Concrete and steel will be problematic for wifi systems.
My house is roughly 3,900 square feet. The building is very thick concrete and brick. The distance between the RBRE and RBSE units varies between 30–40 feet. I’m currently using Auto channel and 40, but I can try 11 and 48.- EkkohNov 21, 2025Tutor
I use iOS 26 but the issue was the same with older iOS. MacOS is Sequoia and Tahoe.
How do I disable IPv6? Only found Pass Through.
It has been happening since day one.
I do understand that concrete is problematic, but I do have full wifi connection on all my devices but still receives 169.254-ip randomly. When streaming on ATV it suddenly freezing since ATV has lost IP-address...
