Ekkoh
Nov 20, 2025Tutor
RBRE960 DHCP issue?
I have an RBRE960 with three RBSE960 units. Two are wired, and one is connected wirelessly. I’m experiencing major issues with my devices losing connection to the network. My iPhone suddenly drops t...
Ekkoh
Nov 21, 2025Tutor
Hi,
thanks!
The device that I have most issue with is my Apple TV, latest version and updated firmware. ATV doesn’t have any private IP-address. But will for sure test on my iOS devices.
Dec 02, 2025Guru - Experienced User
Any progress on this?
What iOS version is on the ATV?
Ekkoh wrote:The device that I have most issue with is my Apple TV, latest version and updated firmware. ATV doesn’t have any private IP-address. But will for sure test on my iOS devices.
- EkkohDec 02, 2025Tutor
IOS 26.1
changed WiFi channel to 11 and 48 and it have been stable since.
- FURRYe38Dec 02, 2025Guru - Experienced User
Ok thanks for the update and details. If this seems to be the fix, Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/000062080/How-do-I-back-up-the-configuration-settings-on-my-Orbi-WiFi-SystemEnjoy. 📡
- EkkohDec 05, 2025Tutor
When I finally thought things had started to work properly, we’re back to square one. Today the iPhone has lost its IP address several times, and the Apple TV as well. This happened after I had a power outage.
I logged in to check the status of the satellites and noticed something very strange. One of the satellites that is connected by cable is connecting to the router via Wi-Fi instead of the cable. - FURRYe38Dec 05, 2025Guru - Experienced User
I would check the wiring in between this one RBS and the RBR. Possible some odd issues in wireing. If the RBS was connected wired and something happened, the RBS will fall back to wireless connection to continue to provide service for devices.
Both of my RBS are stil ethernet connected.
Also have a new iphone 17 in house so I'll be joining the forray of enjoyment with newer generation phones. Oh yay.
I had to leave the house for a while so I couldn’t continue troubleshooting. But when I got back and checked again, the satellite had suddenly switched over to a wired connection without me changing anything. So there definitely seems to be something strange going on with my system.
will have my iPhone 17 on Monday.
Ok, Ya, seems like something on that wired line maybe causing problems. That line will need to be checked.
Yay. Mine arrived yesterday.
