mjschultz
Apr 01, 2026Aspirant
RBRE960 limits MacBook Pro download speeds to 80mbps max
I have an RBRE960 with two satellites all running the latest V7.2.8.5 firmware connected to my provider's router via a Cat 6 ethernet cable. I have a 1 Gbps connection; the 960 consistently shows...
- Apr 02, 2026
Thank you for all of your help.
Out of sheer frustration, I just reset everything. Was much less painful than I thought it'd be in my head.
That seems to have fixed all the issues I've been experiencing, across the board.
Lesson learned.
Apr 02, 2026Guru - Experienced User
mjschultz wrote:I have two MBPs – one a personal one, one work – that 5 GHz connect to the Orbi at a Tx rate of 1,300 Mbps, but have a max download speed of 80 Mbps.
Each MBP is connected to a different satellite.
Have you tried connecting the MBPs without using any of the MBP ports?
Sometimes poorly shielded HDMI and USB cables can cause this issue.
- mjschultzApr 02, 2026Aspirant
Yes. Have tried both without any peripherals plugged in. With power, without power. It's not the MBPs. It's 100% the Orbi.
I have a USB-C to ethernet coming on Friday. That'll tell me definitively if it's the Wi-Fi negotiation, or something else.
Stay tuned.
