mjschultz
Apr 01, 2026Aspirant
RBRE960 limits MacBook Pro download speeds to 80mbps max
I have an RBRE960 with two satellites all running the latest V7.2.8.5 firmware connected to my provider's router via a Cat 6 ethernet cable. I have a 1 Gbps connection; the 960 consistently shows...
- Apr 02, 2026
Thank you for all of your help.
Out of sheer frustration, I just reset everything. Was much less painful than I thought it'd be in my head.
That seems to have fixed all the issues I've been experiencing, across the board.
Lesson learned.
CrimpOn
Apr 01, 2026Guru - Experienced User
How are the Orbi satellites connected to the router? and how far are they from the router?
mjschultz
Apr 02, 2026Aspirant
Both are connected via wireless backhaul. One is about 20 feet away through a floor, the other about 40 feet away.
It's not the backhaul.
I've tested my kid's M3 MBP on the same satellite as the work computer; it gets 700 Mbps.
It's something about how the Orbi is seeing these two specific MBPs.
I just checked: I'm seeing the same issue on my AppleTV, too. It's a mystery.
I'm thinking more and more I just need to bite the bullet and factor reset the Orbi system.
