mjschultz
Apr 01, 2026Aspirant
RBRE960 limits MacBook Pro download speeds to 80mbps max
I have an RBRE960 with two satellites all running the latest V7.2.8.5 firmware connected to my provider's router via a Cat 6 ethernet cable. I have a 1 Gbps connection; the 960 consistently shows...
- Apr 02, 2026
Thank you for all of your help.
Out of sheer frustration, I just reset everything. Was much less painful than I thought it'd be in my head.
That seems to have fixed all the issues I've been experiencing, across the board.
Lesson learned.
