mjschultz
Apr 01, 2026Aspirant
RBRE960 limits MacBook Pro download speeds to 80mbps max
I have an RBRE960 with two satellites all running the latest V7.2.8.5 firmware connected to my provider's router via a Cat 6 ethernet cable. I have a 1 Gbps connection; the 960 consistently shows...
- Apr 02, 2026
Thank you for all of your help.
Out of sheer frustration, I just reset everything. Was much less painful than I thought it'd be in my head.
That seems to have fixed all the issues I've been experiencing, across the board.
Lesson learned.
mjschultz
Apr 02, 2026Aspirant
My next move is to unplug both satellites to see if connecting directly to the base changes things.
- FURRYe38Apr 02, 2026Guru - Experienced User
Be sure to disable any MAC Address randomizers on Macs, phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
What channels are you using on the RBR?
What model MBPs do you have?
What OSX version is on the laptops?
- mjschultzApr 02, 2026Aspirant
- I've tried will all the iCloud/Private Relay/etc. stuff on/off; no difference
- MBPs
- 2019 Intel MBP w/ Sequoia 15.7.5
- 2022 M2 Air w/ Tahoe 26.3.1
- I've tried every combo of channels, but:
- 2.4 GHz: Auto
- 5 GHz: 48
- 6 GHz: 165
Both laptops get >=400 Mbps, a floor away from the provider's Wi-Fi router.- FURRYe38Apr 02, 2026Guru - Experienced User
Which MBP is not working correctly?
Do you have the seprate 6Ghz network enabled on the RBR or is it disabled?
I had my MBP 2018 with OSX 15 on line just in the past couple of months with my 960 series and working well. Manual channels 1 and 40 most used with my system.
