mjschultz
Apr 01, 2026Aspirant
RBRE960 limits MacBook Pro download speeds to 80mbps max
I have an RBRE960 with two satellites all running the latest V7.2.8.5 firmware connected to my provider's router via a Cat 6 ethernet cable. I have a 1 Gbps connection; the 960 consistently shows...
- Apr 02, 2026
Thank you for all of your help.
Out of sheer frustration, I just reset everything. Was much less painful than I thought it'd be in my head.
That seems to have fixed all the issues I've been experiencing, across the board.
Lesson learned.
Apr 02, 2026Guru - Experienced User
Be sure to disable any MAC Address randomizers on Macs, phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
What channels are you using on the RBR?
What model MBPs do you have?
What OSX version is on the laptops?
mjschultz
Apr 02, 2026Aspirant
- I've tried will all the iCloud/Private Relay/etc. stuff on/off; no difference
- MBPs
- 2019 Intel MBP w/ Sequoia 15.7.5
- 2022 M2 Air w/ Tahoe 26.3.1
- I've tried every combo of channels, but:
- 2.4 GHz: Auto
- 5 GHz: 48
- 6 GHz: 165
Both laptops get >=400 Mbps, a floor away from the provider's Wi-Fi router.
- FURRYe38Apr 02, 2026Guru - Experienced User
Which MBP is not working correctly?
Do you have the seprate 6Ghz network enabled on the RBR or is it disabled?
I had my MBP 2018 with OSX 15 on line just in the past couple of months with my 960 series and working well. Manual channels 1 and 40 most used with my system.
- mjschultzApr 02, 2026Aspirant
Both! Those two laptops have restricted bandwidth. My kid has an M3 that connects at 800 Mbps+.
Can't figure it out.
And both show connection rates as slow when connected to the RBS and to the RBR?
