Tajee's avatar
Tajee
RBRE960 loT displaying under Wi-Fi connections
My installer said the the SSID ORBI14-IoT would disappear a few hours after install of the system. It’s been 24hrs and still is listed under my wifi choices. What is this and should it be listed? My main Wi-Fi is ORBI14.
    The User Manual on page 64 describes how the Internet of Things (IoT) WiFi SSID can be controlled by the user.
    https://www.downloads.netgear.com/files/GDC/RBKE963/RBRE960_RBSE960_UM_EN.pdf
    Nothing is going to happen "automatically".  You, as the owner, can use the Orbi admin interface to control the router.
  • FURRYe38's avatar
    The IoT SSID always broadcast unless it's disabled by you.
  • CrimpOn's avatar
    CrimpOn
