MMillerCA
Jun 04, 2024Aspirant
RBRE960 Sony TV (Android TV OS) intermittent connect and disconnect
Since installing firmware V7.2.6.31_5.0.24 my Sony Bravia XR 55A95L "loops" connecting and disconnecting via WiFi. It was working fine before the update. The TV will connect successfully to the bas...
- Jun 04, 2024
Can you try turning OFF one RBS?
Size of home, maybe too much having two RBS deployed.
Also 15 feet is a bit too close between the RBR and the one RBS. 30 feet starting distance.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
MMillerCA
Jun 05, 2024Aspirant
The TV connects and disconnects about every 15 seconds. Here is a screen print of a section of the log showing the process (TV IP address is 192.168.1.25)
When on the TV's network status page it does show the network disconnect and reconnects happening.
I did turn off the RBS that was downstairs and closest to the router and TV. I still got the same error process.
Jun 06, 2024Guru - Experienced User
Can you downgrade the system to v.21 FW, RBS first, the RBR lastly:
