Graz0's avatar
Graz0
Tutor
Jan 11, 2023
RBRE960 Wifi 6 not working
Previously had Huawei WiFi 6 mesh system...cheap but range was poor so I upgraded...#RBE960 is great for the extra output. I previously had super speeds on my iphone 12Pro Max in the old system...but cannot get the router to show me a wifi 6 connection. Also my mac studio ultra has wifi 6 capability.
Cant get wifi 6 enabled - please help!!
- tried the web config adding the separate SSID/wifi 6 checkbox, changing the name and password compared to the 2.4G /5G saved. No SSID for wifi 6
- tried rebooting the router. No SSID for wifi 6
- tried AP mode and Router mode. No SSID for wifi 6
- tried making a support ticket - just got put onto standard docs showing which buttons to push. No SSID for wifi 6
- tried updating all units to latest firmware. No SSID for wifi 6
chatted online to someone - they were really slow...couldnt help...again just got standard look it up answers.
Anyone else here had such issues or have I got a hardware problem and need 3 new units?
supposed to have the 24/7 phone support - requested a call back but nobody has replied to that in ticket 3hrs.
  • wifi 6 and 6ghz are 2 different things.
    wifi 6 just includes 2.4ghz and 5ghz.
    wifi 6E includes 2.4ghz, 5ghz, and 6ghz.
    the iphone 12 doesn't have 6E so no 6ghz.
    Thats why you can't see it.
  • plemans's avatar
    • Graz0's avatar
      Graz0
      Tutor
      darn you are so right....6E is different from 6 and how it is implemented by Netgear. In my Huawei I got really fast speeds on a channel that was reserved for 6 only...just like Netgear have for 6E....looks like another router for my switch until Apple can sort some product upgrades....hopefully next iPhone! til then I will wire connections to hardware.
      Who knows someone may sort a mac version of a usb dongle for 6E standard...I sure would buy one...
      Thanks for your help...and so fast - still no reply from Tech Support on my ticket
      • plemans's avatar
        You might be talking about DFS channels. Netgear does use those but on the orbi it uses them for the backhaul (router---satellite) communication. That way the backhaul isn't the bottleneck in speeds.
        What speeds are you getting over 5ghz?
        the RBKE should saturate most devices over 5ghz without issues.
