klennop's avatar
klennop
RBR/RBS 840 Firmware Update Issues
Hello Everyone, I was doing the manual firmware update to my RBR and RBS 840 items. I have 2 satellites on the system. When doing the manual update the first satellite went fine but the second one...
  • StephenB's avatar
    Mar 13, 2026
    klennop wrote:
    I did the manual update on both the router and the one satellite. However, the issue is with the 2nd satellite. I get the window prompt to update it but I put in the log in and password, the window flashes and then nothing happens, the login and password sits there empty.
    First try "password" as plemans​ suggests.
    You might need to do a paper-clip reset of the satellite and re-pair it with the router.
