RiKShaw
Oct 20, 2024Guide
RBR/S 850 backhaul status out of sync and incapable of updating firmware via IP address
Hello, Recently a power out has caused me to examine our wi-fi setup with our Orbi RBR850 router and RBS850 satellites. While fixing a simple disconnection I noticed that the 'backhaul status' for...
RiKShaw
Oct 23, 2024Guide
How can I downgrade the RBR. Is it as simply as 'updating' to an older firmware?
If so, I still don't know which to pick. It won't tell me what firmware version is on the satellites.
RiKShaw
Oct 23, 2024Guide
So uhh, new development. Apparently I am physically incapable of wanting to downgrade my firmware.
Additionally, I did the factory reset. It didn't appear to help anything. This is the problem I encountered just trying to downgrade to the oldest firmware available.
- FURRYe38Oct 23, 2024Guru - Experienced User
You can't go back that far. You need to downgrade to v7.2.6.21
RBS first then RBR lastly.
Please use this process outlined in the PDF:
- RiKShawOct 26, 2024Guide
Okay I downgraded to the version you suggested for my router and my problems have not changed. The satellites are still slow/unpredictable when connecting and once connected the backhaul status is out of sync, and I cannot retrieve nor send any information in regards to their firmware.
- FURRYe38Oct 26, 2024Guru - Experienced User
So you have not been able to apply any FW or get v.21 loaded on the RBS?
Try this to see if this works:
Manual RBS FW update after RBR was updated:
You need to update the RBS before updating the RBR. Keep this in mind for future updates.What you need to do is factory reset the RBS. Wire connect a PC to the 1st satellite📡. Already have the most current FW version files downloaded on to this PC.
Wire connect 1 PC to the back of the RBS. Factory reset the RBS, wait about 5 minutes. The PC will get a IP address from the satellite📡. The RBS will be 192.168.10.250 for Orbi AX. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password. Use the satellites 📡 web page FW update feature to select the FW update file that was unpacked from the .zip file. Then factory reset and then re-sync the satellites 📡 to the RBR.
