Xendercage
May 03, 2024Star
RBS 760 losing connection with blackhaul or wifi when confiured as AP
Hi
I have a dual Orbi 760 pack with a router a and satelitte.
When i configure Orbi as an Acess Point to prevent double nat between my main routers and ethernet connected devices with the wifi managed bu the orbi,
I have regular deconnection of my satelitte. It is pink in the application / offline.
Same in the webpage for admin.
Satelitte connected to router with ethernet (blackhaul), same behaviour with wifi connection between them.
As soon as i configure Orbi as a router and not acess point, thus deconnection stop to happen....
I had a RBR / RBS 20 during years with same configuration with no issue.
I do not understand what happened.
RBR 760 : 6.3.8.5_1.4.80
RBS 760 : 6.3.8.5
What could be this ?
Can someone help ?
Thanks
There has been no change in the wiring connecting router and satellite? i.e. the cable path from the router LAN port to one of the satellite LAN ports? No switches added to the configuration?
Hello
No changes at all between the two configurations.
Switch exits and are connected directly on my ISP router in both situations
What is the Mfr and model # of the host router or ISP router?
Brand and model# of this switch?
Is RBR connected to the host router using it's yellow WAN port while in AP mode?
How are RBS connected to the RBR in AP mode? Wireless or wired?
