SabbyNZ
Jun 21, 2025Aspirant
RBS350 Satellite loses connection to router
In our two story home, I have a RBR350 router downstairs and a RBS350 Satellite upstairs. Upstairs I have a Playstation 5 connected to the router via a LAN cable. While I know I could connect the...
Jun 22, 2025Guru - Experienced User
Might run thru some of this and see if anything helps:
Orbi MESH Troubleshooting, Suggestions and Tips | NETGEAR Communities
Might try brining the RBS closer to the RBR. 30 feet is starting.
Also for that size of home, you might reduce the RBS deployed by 1. Or change the power on the RBR from 100% to say 50% with two deployed. Try one RBS first with 100% on the RBR.
