Jerry9254
Apr 10, 2026Aspirant
RBS350 Satellites Won't Connect to RBR750 Router
RBR750 router works fine. Recently neither of my two RBS350 satellites will connect. Router and satellites were factory reset. Reouter's Internet connectivity tested good. Router appears in w...
- Jul 11, 2026
Life got in the way so this is a much overdue update. The solution was to give my laptop a static IP, connect the satellites to my laptop via a USB-to-RJ45 network adapter, and manually load an older firmware update from before my problem started. Once I did that, the satellites loaded up and connected to my router without issue. In order to prevent the router from redownloading a more current firmware update that would recreate my problem, I blocked some Netgear domains (frw-update.netgear.com, updates.netgear.com, and firmwareapi.netgear.com). This unexpectedly had the effect of blocking my browser's access to any and all netgear-based sites, including this community. I'm fact, I'm having to make this post via my cell phone and it's 5G connection until I can figure out how to block firmware updates without also blocking community pages.
May 12, 2026Guru - Experienced User
Any progress on this?
Jerry9254 wrote:RBR750 router works fine. Recently neither of my two RBS350 satellites will connect.
Router and satellites were factory reset. Reouter's Internet connectivity tested good. Router appears in web-based and app network viewing options.
Router firmware is up to date.
Attempts to wirelessly connect router and satellites via knowledge base articles don't result in router & satellite sync.
Powering down, waiting 3 mintues, powering up, and trying again don't result in router & satellite sync.
Connecting router and satellite via Cat5 cable gets the satellite light blue, but the satellite still can't be seen in web-based and app network viewing options. Removing the cable after as long as 30 minutes has the satellite light going from blue to white.
What painfully obvious thing am I missing?
