FoReVeRJsUs's avatar
FoReVeRJsUs
RBS750 ethernet port not working
Everything is working but when I tried to connect anything on the satellite using Ethernet port
  • FURRYe38's avatar
    Power OFF and back ON?
    Using good quality LAN cables? CAT6 is recommended.
    MIght contact NG support to see what your options are if nothing helps...
      • FURRYe38's avatar
        Press the reset button for 15 seconds then release then resync. Check the LAN ports.
        Sounds like a HW failure on the RBS...
