jonseff
Oct 07, 2021Tutor
RBS750 firmware update issues
My old Orbi system died and I replaced it with a RBR750 + 2 RBS750 satellites. Had lots of trouble updating firmware and now that I've added a third satellite I'm having the same problems. When I log into the router via a browser, I either get "Update failed" when checking, it gets stucks checking, or it says "No New Firmware Available." I even tried the manual update by downloading the firmware from Netgear and it fails instantly when trying to install. The iOS app simply says there are no updates. Rebooted the whole system and that doesn't work either. This is what I'm currently seeing in the broswer. Any thoughts? [Sigh, inline image doesn't seem to work.]
What happens if you try to manuall download and manually install v3.2.18.1 on the Sat-3 using its IP address on a web browser?
What does SAT-2 have loaded on it if you connect to it's web page?
