furiesmel
May 01, 2026Aspirant
RBS750 Firmware Won't Upgrade
Hello. I picked up an additional Orbi satellite second hand, an RBS750 to go with my RBR750 and an existing satellite. Needed to extend coverage in the house. The satellite is stuck on firmware V...
CrimpOn
May 01, 2026Guru - Experienced User
Since the satellite appears to be working correctly, this might be a case of "if it ain't broke, don't fix it."
Since manual firmware install appears not to work, it might be possible to flash firmware directly to the satellite. Not a simple or risk-free endeavor.
