Gatorsvg
Jul 20, 2025Aspirant
RBS750 Power Supply
Upon a power outage, my RBS750 does not always come back on. After several attempts and plugging and unplugging, including moving the unit, it eventually powers on. Could this be the power supply a...
Jul 20, 2025Guru - Experienced User
Should be able to find a good replacement at amazon by looking for "RBS750 power adapter" Just make sure the voltage and amps specs are the same.
One way to test the RBS out for a quick test to make sure it comes on first time, power OFF the RBR and use the RBRs power adapter for the RBS. After testing put the RBR back online.
