Jrock42432
Apr 02, 2024Aspirant
RBS750 satellite question
I might be an idiot and just have no idea.whats going on but maybe someone can clarify. I have a 2 story house with thick walls so I needed this system. I have my satellites in different t areas and i...
Jrock42432
I didn't know that the firmware situation was a thing. It's currently running v4.6.14.3
So I'll have to dig as to how to manually update it and see if that helps with anything as well as getting a new cable and seeing if that helps.
Thank you for the suggestion and response
Apr 02, 2024Guru - Experienced User
Best practice for manual FW updates:
