home_alone
Jul 15, 2022Tutor
RBS750 satellite
Can I connect the router to one satellite via ethernet for better connectivity?
Are the satellites POE compatible or do they need an external power supply?
That called "wired backhaul".
Search - NETGEAR Communities – wired backhaul
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads. - FURRYe38Guru - Experienced User
home_alone wrote:
Can I connect the router to one satellite via ethernet for better connectivity? Yes.
Are the satellites POE compatible or do they need an external power supply? No.
