AstroCat
Jul 21, 2021Star
RBS850 losing IP access
After some random time after power cycling I lose the ability to access either of my RBS850s (1 wired, 1 wireless) through IP. The overall system is working.
I get this error:
This site can’t be reached192.168.1.45 refused to connect.
Try:
Checking the connection
Checking the proxy and the firewall
ERR_CONNECTION_REFUSED
Any idea why this keep happening?
Thanks.
How are the RBS connected, wireless or wired, too the RBR?
FW: V3.2.18.223 (beta) on both satellites and the router.
No, just a power cycle.
1RBS is wired and the other wireless.
We had the Wifi5 version prior to this, same setup, but never encountered this issue.
It is strange because we can access both satellites right after a power cycle, but at some random time after we lose access and get the error.
I recommend trying a full factory reset and setup from scratch.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://www.youtube.com/watch?v=ePZSc7vnRlQI see you posted about this over in the beta forum. Will continue there as well.
What browser are you using?
Be sure to clear out all browser caches during the factory reset.
