litewait
Sep 01, 2025Aspirant
RBS850 power light flashing amber
I've tried everything, satellite doesn't display an led, just flashes amber on the power light. I've tried factory reset, nothing. Even configured RBR750 it was up and working and couldn't find th...
litewait
Sep 02, 2025Aspirant
Thanks for the help. No matter what reset method I do the power LED flashes Amber over and over, nothing I can do to make it behave any differently. Sigh.
- FURRYe38Sep 02, 2025Guru - Experienced User
Ya, seems like the RBS has gone bad. You might find used replacements on Amazon, ebay or shopgoodwill.
Good Luck.
