litewait
Sep 01, 2025Aspirant
RBS850 power light flashing amber
I've tried everything, satellite doesn't display an led, just flashes amber on the power light. I've tried factory reset, nothing. Even configured RBR750 it was up and working and couldn't find th...
litewait
Sep 02, 2025Aspirant
Wow I am going to take a final crack at it using TFTP, seems if its stuck in recovery mode if I can reach it using tftp I can flash new firmware. Orbi seems to default to 192.168.1.1 per others posts, can't hurt to give it a shot. Appreciate you hanging with me.
Sep 02, 2025Guru - Experienced User
Ya if you can get FW load while in TFTP mode, may get it to recover...Give NMRP Flash a try.
