David9's avatar
David9
RBS850 satellite connectivity poor
Every week or so I am now needing to reboot the RBS850 solution as the backhaul status goes from "good" to "poor". The only fix appears to be to reboot both the router and the satellite.
If I reboot the satellite alone it then comes up with a disconnected error. If I reboot the router alone it comes up with "out of synch".
I have a single satellite node and the Firmware Version is V4.6.14.3_2.3.12. It is running in access point (AP) mode because in router mode it was less reliable for overall internet connectivity.
I purchased these to replace my previous extender so I am now thinking it is just the domestic grade equipment and it needs to be rebooted once a week. Wondering if anyone else has experience this sort of poor operations with their kit?
  • CrimpOn's avatar
    CrimpOn
    It would help to know how far apart the router and satellite are and what lies in the path between them.
    Sometimes there are metallic items hidden inside walls which disrupt WiFi signals and moving one or the other units just a few feet can make a significant difference in the connection.
    In general, how long does the connection stay "Good" before changing to "Pool"?
    • David9's avatar
      David9
      Thanks for following up. The units are Router upstairs in an apartment and the Satellite node downstairs, roughly 10 metres apart if you were to draw a line between them but about 20 metres if you measure down the stairs. There is a concrete slab in between but as I say it is "good" now and has been for about 6 days now.
      Generally it is about 8-14 days as to when it will report "poor". It is not predictable but I am starting to track it.
      I purchased the Orbi units to replace the Netgear extender I previously had as it had a similar sort of issue. Any other ideas you may have are welcome.
