marshall2553's avatar
marshall2553
RBS850 Satellites bricked after downgrading from 4.6.7.5
I installed 4.6.7.5 but was having issues with dropped connections and occasional satellite reboots.  I downloaded 4.6.3.16 from the support page and manually downgraded the satellites followed by the router.  There wasn't any indication that the downgrade failed on the satellites.  Once the router restarted, I loaded a backup of my config from before the 4.6.7.5 upgrade and it seems to be working fine.  The satellites, however, all appear to be stuck in a reboot loop.  They power up, but the LED continually flashes white.  The sync button does nothing, a factory reset did not change things.  Is there anything else I can try?
