Bokeye
Oct 02, 2025Aspirant
RBS850 Stuck in loop / flashing white
Hi all, My RBS850 satelite seems to have bricked itself. It will just continually flash white when on. I've tried the 30/30/30 and variants of that many times. After browsing everything I could...
Oct 02, 2025Guru - Experienced User
After all that and the unit continues this, you'll need to replace the RBS unit.
Bokeye
Hi - thanks for looking. You mean the RBS, right? My RBR is okay as far as I know.
- FURRYe38Oct 02, 2025Guru - Experienced User
Ooops Typo. yes. RBS.
Should be able to find some good used units on amazon, ebay or shopgoodwill sometimes.
- BokeyeOct 02, 2025Aspirant
Thanks - I ordered an ASUS BQ16 Pro mesh setup. I didn't really consider eBay and didn't want to give netgear more money to replace something that crapped out so quickly. I can't say I didn't try to fix it after all that!
Good Luck.
