Bokeye
Oct 02, 2025Aspirant
RBS850 Stuck in loop / flashing white
Hi all, My RBS850 satelite seems to have bricked itself. It will just continually flash white when on. I've tried the 30/30/30 and variants of that many times. After browsing everything I could...
Oct 03, 2025Guru - Experienced User
Consider trying a different power adapter? If you have a spare satellite or even the routers power supply.
You might also try hardwiring it into the router and walking away for a bit after connecting them. Strangely I had one that was on a white boot loop and it corrected itself after hardwiring it into the primary router and walking away. (they were on same firmware versions)
