Beantowm111
Mar 05, 2023Apprentice
RBS850 which port Connect Ethernet?
Hi - when hard wiring an Orbi rbs850 satellite to the router does it matter which of the four Ethernet ports on satellite you use?
None seem marked with an inbound feed indication like with router?
Glad you got it figured out. Might mark it solved so others aren't still trying to fix it
You can hardwire (ethernet) your backhaul to the Orbi satellite using any of its port: https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System. On the Orbi router side, as the picture shows connect to one of its LAN ports (not the WAN port).
- Beantowm111ApprenticeThank you! Figured out I had a bad Ethernet cable which is why o was having an issue.
