Orbi-CA
Feb 01, 2020Aspirant
RBS850 Wireless and wired backhaul with two satellites
I have Orbi RBS850 with two satellites. I would like one of them to be wireless (Kitchen) and one to be wired as its located in the backyard man cave. When I connect the Man Cave satellite directly to the Main Orbi I get the network diagram I would expect (see left side of attached image) with one solid line directly to the Man Cave satellite and a dotted line to the wireless kitchen satellite. However, when I move the Man Cave satellite to the man cave and it's connected to the main Orbi via 4 gigabit switches I get a daisy chain image (see right side of attached image). Everything appears to be working on all the satellites and the main system so I am just not sure if this is a problem or not? I did notice that the RBS850 does not seem to have the setting to turn off daisy chain like some previous versions of Orbi. Thanks for the help.
1 Reply
What is the Mfr and model# of the ethernet switch in the configuration?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerPossible that the app maybe incorrectly displaying how they are connected. I know the one time I had the RBS connected via wireless and the other wired, It appeared correctly as in the 1st pictures on the left. However placement is key as well. The one RBS I have is down in the basement at the far end of my home opposite from the RBR. The other RBS is just down stairs about 25 feet away from the RBR and most on the side of the home were the RBR is located. My Orbi app now shows that both are wired however shows being connected all in a line out from the RBR like your pictured on the right, however since both of my RBS are wired, there is no dotted line.
I presume the Orbi app is displaying ok, however could display it better. Operation would be find however.
