ZeeSK
Jul 18, 2025Aspirant
RBSE960 running at half speed
Hello everyone, I have an Orbi 960 series router (RBRE960) and an add-on satellite (RBSE960), both devices are firmware version V7.2.7.15. the router and the satellite are connected via wireless ...
Jul 19, 2025Guru - Experienced User
Concrete thru two walls will be problematic for any MESH system over wireless. All the concrete and steel will inhibit good wifi signal travel and coverage and performance.
I recommend trying to get the RBS ethernet connected to the RBR. Either direct ethernet cable or try either MOCA or PowerLine adapters in between the RBR and RBS.
- ZeeSKJul 20, 2025Aspirant
Thanks FURRYe38, As mentioned in my original post however, my satellite always connects to the router with a solid blue color, indicating no issues with the connection. I have never had any connection issues with the wireless backhaul itself (satellite disconnecting, etc.) Additionally, the setup works perfectly for about 10 days after a fresh reset with the same positions described.
Even if this was an issue due to distance/ concrete walls, why is the speed dropping to almost exactly half? my speedtests consistently score around 450 Mbps up and down when connected to the satellite. I believe something in my settings may be impacting the satellite performance.
- FURRYe38Jul 20, 2025Guru - Experienced User
Try a factory reset and setup from scratch and see.
