macbates
Oct 16, 2020Aspirant
'Can't find server' errors with ORBI 753
I’m having some Internet issues with a newly installed Orbi RBK753 system, and haven’t been able to figure out how to solve them. What happens is that I will quite often get a “Safari can’t connect t...
Nov 01, 2020Guru - Experienced User
You modem already has a built in router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
ATT Modems:
https://www.f0il.com/how-to-arris-bgw210-700-modem-router-with-netgear-xr500-router/
https://community.netgear.com/t5/Orbi/How-do-I-setup-bridge-mode-in-the-ARRIS-BGW210-700/m-p/1875994/highlight/true#M84982
ATT Dumb Switch Method:
https://community.netgear.com/t5/Orbi-AX/Orbi-AX-6000-and-AT-amp-T-fiber-gateway-issue/m-p/1890125/highlight/true#M2756
Thalador wrote:It is on current, 3.2.16.6_1.4.4
at&t arris bgw210 modem.
Thalador
Nov 01, 2020Apprentice
Way ahead of you. I had an RBR50 prior and already have my AT&T set to passthrough. No double nat here
FURRYe38 wrote:You modem already has a built in router, This would be a double NAT (two router) condition which isn't recommended.
- FURRYe38Nov 01, 2020Guru - Experienced User
Something to try as well, set the ISP modem back to router mode and change the RBR to AP mode and see if the Can't Find Server messages still appear...
- 2rjDec 13, 2020Aspirant
I am having the same problem with a brand new Orbi 753. Every so often following a link will get "server not found". Very intermittment and no pattern to it that I can see, sometimes its at a site I have never visited before, sometimes its a site I was at an hour ago. Once happened checking email via pop (at gmail).
This problem started a day after replacing a TP Link mesh network with the Orbi mesh network. Negear support has not been of much help, suggested diabling WiFi 6 and going to an older firmware version, neither of which helped. - FURRYe38Dec 13, 2020Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Is Armor enabled?
- ThaladorDec 14, 2020Apprentice
I fixed my issue by getting an RMA AND more importantly not enabling access control. Once I do it all but hoses the system. Disabled it works 100%
