hTep
Oct 27, 2025Guide
How to track backhaul or satellite issue
Hello, I'm using an Orbi RBR750 with 2 satellite. All firmware are up to date. One of my satellite is a little bite far and connection status is poor. however, bandwidth are very good. Bu...
hTep
Oct 27, 2025Guide
hello,
no change on the led color, log are so poor, how could I trouble shoot if my Mac prefers connect to other satellite?
Last firmware is loaded.
My home +150 m2 (1615 sq ft) on 3 levels
routeur is at the center of the home, sat in question is l+2 (vertical of the rbr)
think it’s a huawei or Nokia ONT, no pb with that all other devices work.
Yes connected by wire to the routeur, if led doesn’t change you are right to notice that, maybe he does not lost BH.
Sat is maybe a little bit away of 30 ft. There are material yes…
How can I read channel of my configuration?
wifi 2.4:auto
wifi 5:40
sounds good?
thanks for your help
Oct 27, 2025Guru - Experienced User
What version number is the FW on the system?
What is the model# of the ONT?
For that size of home, the RBR and maybe just one RBS would be needed. Not two.
Too Much Wifi: https://youtu.be/UR0viMLISz4
Lets turn OFF one RBS for now.
Try channel 1 and 40 or 11 and 48.
hTep wrote:no change on the led color, log are so poor, how could I trouble shoot if my Mac prefers connect to other satellite?
wifi 2.4:auto
wifi 5:40
sounds good?
