liamscor
Jun 10, 2025Luminary
I found that disabling all logging and then performing a full power cycle of my 963 system
I found that disabling all logging and then performing a full power cycle of my 963 system—a step I came across in the post linked below (which discusses BE systems)—resulted in a significant perform...
liamscor
Oct 24, 2025Luminary
Just an update on this, I have found that if you have netgear armor enabled, there then seems to be some issue related to the logging, I have now factory reset and setup from scratch via the via web gui and not used the orbi app, and haven't had to disable any logging.
- FURRYe38Oct 24, 2025Guru - Experienced User
Good ol Armor doing stuff.
Wondering if you used Orbi app and disabled Armor in the app, does problem still continue?
