KMDonlon
May 13, 2026Virtuoso
IPv6
Since replies have been turned off on all previous discussions regarding the IPv6 trouble introduced with version 7.2.7.15 and newer, I needed to create a new thread. Checking in on this once aga...
andrenb
May 15, 2026Aspirant
I'm on V7.2.6.31_5.0.24 for my set of Orbi 750's. They are set up in AP-mode with a Ubiquiti UniFi Cloud Ultra doing the routing, with IPv6 working fine.
Will I be affected with IPv6 stopping to work on Wifi if I upgrade to a newer FW for the Orbi 750 or is this only when using the Orbi in router mode?
May 15, 2026Guru - Experienced User
If its in AP mode, its the Ubiquiti managing that aspect. You can upgrade without worrying about IPv6.
