rpd1116
Apr 04, 2026Aspirant
Issue when rebooting RBR750P - router continually cycles and requires reset
I have an issue when rebooting my RBR750P. Every time I do a reboot, the router stops working. It will come back up, but I am unable to connect to it. My Wifi network will appear on my devices but I ...
rpd1116
The modem is Arris TouchStone CM8200A. The LAN cable is a good one (CAT6).
I didn't know about the RBR /debug.htm page. I see an option to "Start Debug Log Capture when boot up" I will try as a possible option. The issue that I continue to struggle with is that I can't seem to access the router in any possible way after a reboot so I have no idea what the logs record. And when I factory reset (both of the options you listed are the reset I am doing, so I can confirm I am already performing a "factory reset").
Is there a way to stream the logs off the router some other way?
I have 3 satellites but when I reboot I can't connect to personal wifi so can't do anything with them. When I factory reset, the satellites do automatically re-sync.
Apr 06, 2026Guru - Experienced User
Are you trying to access the router via its IP address? using the orbilogin . net address?
Have you tried other browsers?
