ABuYang
Oct 27, 2025Tutor
LINE App Cannot Send or Receive Messages When Connected to RBR750 WiFi
Hello All, Since two days ago, mobile devices (iPhone 16 and older Android) connected to our RBR750 WiFi cannot send or receive messages on LINE, and LINE VOOM videos fail to play. Switching to mobi...
Oct 27, 2025Guru - Experienced User
Something to get help from the app Mfr about regarding there app.
Armor, Smart Parental Controls or Circle, IPv6, Traffic Meter.
Try disabling AX mode on the RBR. Under Basic/Wireless check box.
- ABuYangOct 27, 2025Tutor
Hi,
Thank you for your reply.
🔹 Information from LINE App Support
According to the official LINE App support page, for connection-related issues, it is recommended to switch between different network types — such as WiFi and mobile data (4G/5G) — to help identify the cause.
If the app functions normally after switching, it usually indicates that the problem is related to the network equipment, and users are advised to contact their network device provider for further assistance.🔹 Network Device Information
The upstream device connected to the RBR750 is a Nokia G-0425G-P GPON HGW, which was provided by the ISP during the internet installation.
🔹 Tested Actions
The following features have been disabled for testing, but the issue persists:
Netgear Armor
Smart Parental Controls / Circle
IPv6
Traffic Meter
Additionally, AX mode was also disabled for testing, but this did not resolve the problem either.
🔹 Additional Observations
This network setup has been running normally for over two years without any issues until this problem suddenly appeared two days ago.
All other apps requiring internet access (e.g., Instagram, Facebook, Email, Telegram) continue to work perfectly — only LINE is affected.Since LINE is a very popular and widely used app in our region, and Netgear products are known for their high-end performance and reliability, this situation is quite puzzling.
🔹 Request for Further Assistance
If there are any additional suggestions or troubleshooting steps that I can try, please kindly let me know.
Thank you very much for your support.- FURRYe38Oct 27, 2025Guru - Experienced User
Are you using ISP DNS or custom DNS on the RBR?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
Static IP Address Configuration for AP Mode | NETGEAR Communitieshttps://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...- ABuYangOct 28, 2025Tutor
Thank you for the information.
The RBR is currently using custom DNS settings, configured as follows:
8.8.8.8
1.1.1.1
168.95.1.1 (this one is a public DNS provided by the local ISP)
The ISP modem does have an indicator light for WiFi, but it seems that the ISP has already disabled the WiFi function.
Based on the setup, it appears that my network is already configured according to Option 2.The ISP modem is connected to two devices:
MOD
RBR750
However, I cannot log in to the ISP modem or MOD to check their configurations.
The RBR750 obtains its IP address directly from the ISP modem,
so this setup should match the Option 2 configuration you described.These hardware connections have remained unchanged for more than six months.
If there are any further tests or settings you would recommend trying, please feel free to let me know.
