ABuYang's avatar
ABuYang
Tutor
Oct 27, 2025
LINE App Cannot Send or Receive Messages When Connected to RBR750 WiFi
Hello All, Since two days ago, mobile devices (iPhone 16 and older Android) connected to our RBR750 WiFi cannot send or receive messages on LINE, and LINE VOOM videos fail to play. Switching to mobi...
  • StephenB's avatar
    Oct 28, 2025
    ABuYang wrote:
    The ISP modem is connected to two devices:
    MOD
    RBR750
    What is MOD???
    ABuYang wrote:
    The RBR750 obtains its IP address directly from the ISP modem,
    so this setup should match the Option 2 configuration you described.
    Maybe not.  Is the RBR750 getting a private IP address from the ISP?  The private address ranges are
    • 10.0.0.0 to 10.255.255.255
    • 172.16.0.0 to 172.31.255.255
    • 192.168.0.0 to 192.168.255.255.
    Have you tried connecting a PC to one of the gateway (modem) ethernet ports, and see if you can access LINE w/o using the RBR750?
