checkyourmirror
Dec 31, 2025Aspirant
Main 960 in AP Mode doesn't show Satellites in Attached Devices over enet
I've been using my 960 in Router mode with two satellites backhauled over ethernet, and everything was working great. I could see the satellites in the attached devices. I switched over to using the ...
checkyourmirror
They are all connected to the switch and I think you are saying they have to be connected to the RBR? That isn't a great scenario since I have a 2.5Gb internet connection, and only ONE of the RBS could connect to 2.5Gb to the RBR, the other would be stuck with 1Gb since that is all the ports that are left.
I just tried your suggestion and sure enough they show up in attached devices now!!!! The challenge is one of the AP's is running 1Gb on the backhaul so I'm losing 1.5Gb to the Internet by requiring it to go through the RBR.... Ugh Can't say I am happy about this but have them as "peer" ethernet connections is challenging since config changes, firmware updates, etc aren't seen and I guess I question if the mesh aspect would work.
Any other suggestions or am I basically screwed because the RBR doesn't have more 2.5Gb ports?
PS: I tired to upload a diagram but I kept getting a "Media Upload in progress, try again later" and they the images aren't that big so I gave up...
Jan 01, 2026Guru - Experienced User
Where is this switch connected?
What is brand and model# of this switch?
If you get a 2.5Gb supporting non managed switch connected at the RBR, then you can connect all RBS to this switch and will get 2.5Gb rates to the RBS.
- checkyourmirrorJan 01, 2026Aspirant
I will give that a try this weekend and report back, and curious what is it about a managed switch that causes the problem? I am using a low-end Netgear managed switch and like many wanted to keep the brand consistent to avoid problems like this.
